Blender Crash entering look dev mode
Operating system: dual xeon x5680 @3.33Ghz (2 processors) 24GB RAM. Win 64bit
Graphics card: Nvidia gts 450
Broken: 2.80 Beta, 4fe0fafb8 master, 2019-07-24
Worked:
When entering look dev mode blender crashes
in this case I think it is caused by the build of this PC (my brother pc)
He doesn't use ir for 3D rendering, mostly to calculate structures so he doesn't need a good graphics card, but cores. Maybe is because of this graphic card is too old. Or maybe It is the dual xeon... I don't know. Is not a .blend file problem. Thats for sure, because it happens with any blender file
Can you update your GPU drivers to last avaible from Nvidia site and confirm this problem?
Please, update this report following strictly this form https://developer.blender.org/maniphest/task/edit/form/1/
The operating system, main memory size, GPU brand and model, GPU driver version and Blender hash or its build date may be needed by developers to investigate this issue
You can check here https://www.blender.org/download/requirements/ if your hardware and software meet minimum Blender requirement, if not, you can consider this report as invalid until Blender developers validate this issue
thank you
Yes, it worked perfectly, I downloaded the latest drivers from NVIDIA and now I can enter Look Dev mode and Rendered Mode without problems. Thanks!
dark999 (dark999) changed the task status from Unknown Status to Resolved.Jul 30 2019, 8:41 PM
dark999 (dark999) claimed this task.
