Blender 2.80 RC1-2-3 Crash While Rendering - flicker, white blank screen, blue screen of death
Operating system: Windows 10 Home, built 1903
Graphics card: ASUS R9 290X DirectCU II OC
Broken: Blender 2.80 RC1, RC2 and RC3{F7629090}
After a few renderings, while rendering screen starts to flicker. Cannot shut down Blender normally, have to use task manager to end task. After that Blender does not restart without a windows restart. I had experienced this with all versions of the RC releases. I also managed to capture this in the console window, see attached. That was before the blue screen mentioned below.
As I was writing this the first time I tried to restart Blender and the blue screen of death came up the first time, with the message Stop Code: Video_Scheduler_Internal_Error.
Andrew Sprok (sprad001) renamed this task from Blender 2.80 RC1-2-3 Crash While Rendering - flicker, white brank screen, blue screen of death to Blender 2.80 RC1-2-3 Crash While Rendering - flicker, white blank screen, blue screen of death.Jul 26 2019, 5:20 AM
Stephen Swaney (stiv) lowered the priority of this task from 90 to 30.Jul 26 2019, 5:27 AM
Cycles or EEVEE ? Sounds rather like an unsupported graphics card.
Sorry, forgot to mention that is Cycles.
This graphics card was working with all the previous development versions of Blender. I have been using V2.80, in conjunction with V.2.79, ever since it became available and I downloaded a fresh version every week once, except the last month or so. I used the same computer during this time.
Had the same Problem last week at home.
I was viewport rendering with cycles. Had a volume shader and connected a noise texture to the volume shader density inputs.
Then suddenly flickering of one monitor the other monitor switched off completely. Then after a few seconds blue screen of death with the above message.
My system specs: Windows 10 Pro x64 1903
Nvidia Geforce GTX 1080 Ti
I then updated my graphiccard drivers but had a blue screen of death again in blender.
Today tested the same scene on my laptop. On my laptop blender crashed with an OpenGL driver error.
For test purposes I set a new value in the registry:
([HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers]
add a new dword called "TdrDelay" and set the hex value to 40 or more.
"TdrDelay"=dword:00000040)
This advice I found on the ecycles forum.
Now I have no crash anymore!
Laptop specs: Windows 10 Pro x64 1903
Nvidia Quadro M5000M
The flickering starts on my main screen where the main Blender window is and a few moments later it stars on the second monitor as well and from there it goes to rest of the blank screen, loosing screen output and so on.
Looks like this problem remains even in Blender V2.81 Alfa
Bastien Montagne (mont29) raised the priority of this task from 30 to 80.Aug 13 2019, 6:01 PM
I still have issues even though I updated the AMD driver twice. Today I did it the second time to the absolute latest one. When I use GPU render most of the time this happens.
After the screen flickering it ends up like this, white windows. When closing the program via the close windows or Task Manager, after restarting it goes into flickering straight away and the white screen. This is on both the 2.80 ad 2.81 as well.
Richard Antalik (ISS) changed the task status from Needs Information from Developers to Needs Information from User.Jan 6 2020, 11:02 AM
@Andrew Sprok (sprad001) does this still happen with latest build? https://builder.blender.org/download/
Richard Antalik (ISS) closed this task as Archived.Jan 16 2020, 12:04 PM
Richard Antalik (ISS) claimed this task.
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to close the report.
