workbench engine crash
Graphics card: Intel(R) HD Graphics 4000 Intel 4.0.0 - Build 10.18.10.5059
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 14:22, hash: rB507ffee6e1f4
blender crashes every time i try to render with the workbench engine{F7630205}
switch to workbench engine, set render samples, set lighting to MatCap with random color, enable outline with default color, enable cavity with type set to both
Eitan Traurig (EitanSomething) lowered the priority of this task from 90 to 30.Jul 26 2019, 8:40 PM
Please make sure you graphics drivers are up to date. If they aren’t please update them.
this issue is already reported from other users, to try mitigate your issue, upgrade your GPU drivers to latest availble from Intel site, however Intel HD Graphics 4000 GPU and older not meet minimum Blender requirement
Next time you can use Help > Report a Bug item and striclty follow this form. Attach a simplest possible .blend file, before you made a bugreport you must search if bug/issue is already reported from others users
thank you
Sybren A. Stüvel (sybren) changed the task status from Unknown Status to Unknown Status.Aug 6 2019, 2:38 PM
Sybren A. Stüvel (sybren) claimed this task.
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
