Operating system: Windows 10 Pro
Graphics card: nVidia 1080 GTX
Broken: blender-2.80rc3-windows64
All buttons show red "internal error"
Unable to select anything.
Cannot select Objects in 3D view or collections panel.
Cannot navigate in 3D view.
Cannot open item properties panel. (Side panel in 3D view you pop open to view the selected item's information)
Cannot adjust panel sizes.
Can select menu items.
Can operate most all of the properties panels. (Render, Modifiers, etc)
Can apply modifiers
Based on the default startup. Is immediately in this state upon opening 2.8.
History: I have run Blender 2.8 previously successfully. I believe this issue first was realized Dec 2018. rc3 still still inoperable.
Have tried on several other computers both at home and at work with same results.
Blender 2.79 operates without any problems.
Have seen past same/similar bug reports, however all are closed.
Below is a dump from the blender console showing a lot of errors coming from the Python "re" module attempting to use the enum.IntFlag.
Followed by a constant flow of keymap errors pointing at a K: drive on Git
Note: looking back at a Dec build, it has the same regex "re" error, followed by continuous `"Keymap: '3D View Tool: Select Box' not found for tool 'Select Box'"` errors
CONSOLE:
Read prefs: C:\Users\B4adle7\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
found bundled python: D:\_install\Blender\blender-2.80rc3-windows64\2.80\python
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\addon_utils.py", line 351, in enable
mod = __import__(module_name)
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\addons\io_scene_gltf2\__init__.py", line 63, in <module>
from io_scene_gltf2.io.exp import gltf2_io_draco_compression_extension
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\addons\io_scene_gltf2\io\exp\gltf2_io_draco_compression_extension.py", line 18, in <module>
from pathlib import Path
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\python\lib\pathlib.py", line 1, in <module>
import fnmatch
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\python\lib\fnmatch.py", line 14, in <module>
import re
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\python\lib\re.py", line 143, in <module>
class RegexFlag(enum.IntFlag):
AttributeError: module 'enum' has no attribute 'IntFlag'
During handling of the above exception, another exception occurred:
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\__init__.py", line 81, in <module>
main()
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\__init__.py", line 78, in main
utils.load_scripts()
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\utils\__init__.py", line 272, in load_scripts
_initialize()
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\addon_utils.py", line 47, in _initialize
enable(addon.module)
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\addon_utils.py", line 359, in enable
handle_error(ex)
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\addon_utils.py", line 299, in handle_error
import traceback
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\python\lib\traceback.py", line 5, in <module>
import linecache
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\python\lib\linecache.py", line 11, in <module>
import tokenize
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\python\lib\tokenize.py", line 33, in <module>
import re
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\utils\__init__.py", line 187, in register_module_call
register()
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\startup\bl_operators\__init__.py", line 70, in register
register_class(cls)
ValueError: register_class(...): already registered as a subclass
main()
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\utils\__init__.py", line 260, in load_scripts
test_register(mod)
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\utils\__init__.py", line 229, in test_register
register_module_call(mod)
File "D:\_install\Blender\blender-2.80rc3-windows64\2.80\scripts\modules\bpy\utils\__init__.py", line 189, in register_module_call
import traceback
import linecache
import tokenize
import re
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Edit Mode'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint Mode'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint (Draw brush)'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint (Erase)'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Paint (Fill)'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Grease Pencil Stroke Sculpt Mode'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Face Mask'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Weight Paint Vertex Selection'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Pose'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Object Mode'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Paint Curve'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Curve'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Image Paint'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Vertex Paint'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Weight Paint'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Sculpt'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Mesh'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Armature'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Metaball'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Lattice'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Particle'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Font'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Object Non-modal'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Frames'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap '3D View Generic'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap '3D View'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Window'
WARN (wm.keymap): K:\BlenderGit\blender\source\blender\windowmanager\intern\wm_keymap.c:467 WM_keymap_poll: empty keymap 'Screen'
