Bevel and skin modifier results in intersecting geometry artifacts
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 12:32, hash: rBbfe580642f46
An wire edge mesh combined with a vertex bevel modifier and skin modifier creates bad geometry. Here's a picture showing the problem:
  1. Make a simple, angular wire edge mesh.
  2. Add a bevel modifier with only vertices ticked.
  3. Add a skin modifier.
  4. (Optional) Add a subdivision surface modifier to make the problem more apparent.
Here's a blendfile with the models shown above:
http://pasteall.org/blend/index.php?id=52104
Potential solutions:
  1. Change how the skin modifier does tessellation on smaller edges.
  2. Make the wireframe modifier work on wire edge meshes (it wouldn't create this extra geometry to begin with).
In your .blend file, problematic vertex at beveled angle with deformation is assimilated as Root.
You can fix the problem by entering edit mode, selecting one vertex at a tip of mesh and pressing Mark Root button.
Robin Karlsson (nosslak) changed the task status from Unknown Status to Resolved.Jul 28 2019, 10:30 PM
Robin Karlsson (nosslak) claimed this task.
Ah, right, I see. Thank you, Ronan. I'll just mark this as Resolved.
