Grease Pencil Noise modifier step is ignored in render
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 570 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.20
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-24 14:22, hash: rB507ffee6e1f4
setting noise step to 6 should update the noise value every 6 frame. In render this value is ignored and updated (seemingly interpolated) each frame.
open the attached blend file and play the animation in viewport. The noise on the stroke will be updated correctly. Then render the sequence and look at the result.
@Antonio Vazquez (antoniov) after applying your patch the interpolation is gone but the noise still behaves very different from viewport and render. In render seems to just pop to the same noise value each step and then pop back to no noise value.
Can you please compare viewport and video render output to check if this is working as intended?
viewport:
render output:
Antonio Vazquez (antoniov) changed the task status from Resolved to Unknown Status.Jul 31 2019, 4:37 PM
It's strange...in my PC is not working equal... I will look again.
Antonio Vazquez (antoniov) lowered the priority of this task from 90 to Normal.Jul 31 2019, 4:37 PM
I have redesign how the noise random values work in D5393.
