Crash upon selecting materials tab from object tab
Operating system: Darwin-17.7.0-x86_64-i386-64bit 64 Bits
Graphics card: NVIDIA GeForce GT 750M OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-10.32.0 355.11.10.10.40.102
Broken: version: 2.80 (sub 75), branch: unknown, commit date: 1970-01-01 00:00, hash: rBunknown
[Crash]
With object tab selected, chose materials tab
I can confirm I see this issue with quadro 4000 series card. If I create a new general project and access materials, blender quits within a few seconds at most.
NVidia Driver version 353.62 (latest supported driver for the Quadro 4000)
Windows 10 x64 1803
I've attached the system Info file from blender for your information. I also tried the last version before release that i had installed, RC2 and it behaves the same way. The development build of 2.81 Alpha from 6th August 2019 is also behaving in the same way.
I know a colleague who has a Quadro P5000 has no issue and I don't recall seeing it on a GTX 1060 either. Note: Can confirm no issue with a GTX 1060 so probably related to cards that are only supported by older drivers. However, in the case of the Quadro 4000 which is a decent card, this is really not ideal.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Sep 11 2019, 1:26 AM
Please upgrade your GPU drivers to the latest official drivers from nvidia.
(This is the usual cause and solution for this bug).
If this doesnt help, please also try a fresh build from https://builder.blender.org/download/
Please report back if the issues persist after trying this, thx.
The drivers I mentioned are the only available drivers for the card, which I mentioned above. They have stopped issuing newer drivers so if it doesn't work with those, it won't work.
As it happens I got my PC replaced recently so for me it isn't an issue any more (RTX5000 + latest supported drivers = works fine, same version of OS) but it was incredibly frustrating before this happened.
The issue in the original report is for macOS and with a specific .blend file.
Crashes with a Quadro 4000 are unrelated, and we've had other reports confirming that installing the latest driver helps for that case, which is version 377.83.
https://www.nvidia.co.uk/Download/driverResults.aspx/130250/en-uk
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Sep 25 2019, 10:45 AM
