Transfer Mesh Data with Custom Normal crash when Auto Smooth is enabled
Graphics card: 67EF:CF ATI Technologies Inc. 4.5.13474 Core Profile Context 22.19.162.4
Transfer Mesh Data with Custom Normal crash when Auto Smooth is enabled.
  1. Enable Auto Smooth in default cube.
  2. Add Ico Sphere
  3. Select both mesh, and make the cube active.
  4. Run Transfer Mesh Data from Object > Relations > Transfer Mesh Data
  5. Select Custom Normals
  6. Crash
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.Aug 5 2019, 10:39 AM
Can confirm, checking...
Asserts here, problem with cddata_masks, comment says
This should be ensured by cddata_masks we pass to code generating/giving us me_src now.
but apparently isnt...
BLI_assert(CustomData_get_layer(&me_src->pdata, CD_NORMAL) != NULL);
1  raise                                                             0x7ffff1ae6e75
2  abort                                                             0x7ffff1ad1895
3  data_transfer_dtdata_type_preprocess data_transfer.c        288   0x20488f4
4  BKE_object_data_transfer_ex          data_transfer.c        1491  0x204acba
5  BKE_object_data_transfer_mesh        data_transfer.c        1891  0x204bbaf
6  data_transfer_exec                   object_data_transfer.c 476   0x2cf786d
7  WM_menu_invoke_ex                    wm_operators.c         751   0x23e7f88
8  WM_menu_invoke                       wm_operators.c         771   0x23e80dd
9  wm_operator_invoke                   wm_event_system.c      1438  0x23c7cd3
10 wm_operator_call_internal            wm_event_system.c      1651  0x23c8470
11 WM_operator_name_call_ptr            wm_event_system.c      1699  0x23c8693
12 ui_apply_but_funcs_after             interface_handlers.c   835   0x2a733c0
13 ui_popup_handler                     interface_handlers.c   10259 0x2a8b228
14 wm_handler_ui_call                   wm_event_system.c      623   0x23c5cb7
15 wm_handlers_do_intern                wm_event_system.c      2699  0x23cabbc
16 wm_handlers_do                       wm_event_system.c      2945  0x23cb857
17 wm_event_do_handlers                 wm_event_system.c      3323  0x23cca27
18 WM_main                              wm.c                   417   0x23c04b8
19 main                                 creator.c              491   0x1d7ac06
@Bastien Montagne (mont29): mind checking?
