Crash when rapitedly setting custom property on material node tree
Closed, DuplicatePublicBUG
Operating system: Linux-4.15.0-55-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.40
When using custom properties defined via Python on materials node tree, blender will crash after you set the property for a few times.
First variant:
  1. Open attached blend file:
  1. Run the script
Second variant:
  1. Open default blend file.
  2. Run this script:
import bpy
def timer():
    material = bpy.data.materials["Material"]
    material.blend_method = "OPAQUE"
    node_tree = material.node_tree
    node_tree["test"] = "test"
    return 0.01
bpy.app.timers.register(timer, first_interval=0.01)
Simon (notallowed) updated the task description. (Show Details)
If you run blender with --debug-memory, it spams complaints about 'double free', and that happens even with a very much simplified test:
import bpy
def timer():
    return 0.01
Assigning blend_method seems to be the critical part.
Can confirm what angavrilov wrote, setting blend method together with assignment of custom property is a killer. Will update main post.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.Aug 8 2019, 1:29 PM
Only happens when the Properties Editor, Material context of that particular material is open (doesnt happen in any other context or with a different material showing...)
Assume this is because of Material preview/thumbnail generation? [wasnt this delayed somehow to not slow down the UI while editing materials that much?]
1   std::__detail::_Hash_code_base<GPUBatch *, GPUBatch *, std::__detail::_Identity, std::hash<GPUBatch *>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, false>::_M_bucket_index        hashtable_policy.h  1300 0x6c5f12f
2   std::_Hashtable<GPUBatch *, GPUBatch *, std::allocator<GPUBatch *>, std::__detail::_Identity, std::equal_to<GPUBatch *>, std::hash<GPUBatch *>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true>>::_M_bucket_index         hashtable.h         640  0x6c5e8cf
3   std::_Hashtable<GPUBatch *, GPUBatch *, std::allocator<GPUBatch *>, std::__detail::_Identity, std::equal_to<GPUBatch *>, std::hash<GPUBatch *>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true>>::_M_find_before_node     hashtable.h         1554 0x6c5dc93
4   std::_Hashtable<GPUBatch *, GPUBatch *, std::allocator<GPUBatch *>, std::__detail::_Identity, std::equal_to<GPUBatch *>, std::hash<GPUBatch *>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true>>::_M_find_node            hashtable.h         655  0x6c5da30
5   std::_Hashtable<GPUBatch *, GPUBatch *, std::allocator<GPUBatch *>, std::__detail::_Identity, std::equal_to<GPUBatch *>, std::hash<GPUBatch *>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true>>::_M_emplace<GPUBatch *&> hashtable.h         1658 0x6c5d295
6   std::_Hashtable<GPUBatch *, GPUBatch *, std::allocator<GPUBatch *>, std::__detail::_Identity, std::equal_to<GPUBatch *>, std::hash<GPUBatch *>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true>>::emplace<GPUBatch *&>    hashtable.h         749  0x6c5cf78
7   std::unordered_set<GPUBatch *>::emplace<GPUBatch *&>        unordered_set.h     377  0x6c5c9ae
8   gpu_context_add_batch        gpu_context.cpp     291  0x6c5c1c3
9   batch_vao_get        gpu_batch.c         236  0x6c4f899
10  GPU_batch_program_set_no_use        gpu_batch.c         323  0x6c4fc4e
11  GPU_batch_program_set        gpu_batch.c         328  0x6c4fc80
12  GPU_batch_program_set_builtin_with_config        gpu_batch.c         681  0x6c50d14
13  GPU_batch_program_set_builtin        gpu_batch.c         686  0x6c50d3c
14  UI_widgetbase_draw_cache_flush        interface_widgets.c 1251 0x2ad5798
15  icon_draw_size        interface_icons.c   1811 0x2a93ff2
16  UI_icon_draw_ex        interface_icons.c   2277 0x2a95343
17  widget_draw_icon        interface_widgets.c 1526 0x2ad64aa
18  widget_draw_text_icon        interface_widgets.c 2387 0x2ad873c
19  ui_draw_but        interface_widgets.c 4827 0x2ae0747
20  UI_block_draw        interface.c         1710 0x2a5babc
@Jeroen Bakker (jbakker), @Clément Foucault (fclem) might know more?
Jeroen Bakker (jbakker) changed the subtype of this task from "Report" to "Known Issue".Jan 10 2020, 2:42 PM
It is not reproducable via the small script, but the file still fails. On my machine it crashes in the driver. Perhaps another thread is free-ing resources that is still used during drawing.
In other parts in blender we lock the rendering. But that isn't possible here. There are more related issues eg rendering with a frame change.
Campbell Barton (campbellbarton) changed the subtype of this task from "Known Issue" to "Bug".
