Grease Pencil: L (key) / cmd z / crash
hi there
it happens that blender grease pencil crashes regularly, when I'm in drawing modus and press:
l (L Key) - then cmd+z
best
jadi
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
hi there
best
jadi
Antonio Vazquez (antoniov) lowered the priority of this task from 90 to 50.Aug 8 2019, 5:24 PM
@Charlie Jolly (charlie) The error is gpencil_paint.c
case GP_PAINTMODE_DRAW: {
          GP_Sculpt_Guide *guide = &p->scene->toolsettings->gp_sculpt.guide;
          if (guide->use_guide) {
            ED_workspace_status_text(
The guide is NULL.
I assign to you. If you don't find the problem let me know.
I have seen after undo, the p has NaN
static int gpencil_draw_modal(bContext *C, wmOperator *op, const wmEvent *event)
  tGPsdata *p = op->customdata;
I don't know why. It looks the Undo is running while the modal operator is still running.
@Campbell Barton (campbellbarton) any idea here?
Philipp Oeser (lichtwerk) renamed this task from L (key) / cmd z / crash to Grease Pencil: L (key) / cmd z / crash.Aug 9 2019, 9:43 AM
@Philipp Oeser (lichtwerk) Not sure this problem is only GP. I tested and the problem is the customdata of the operator is corrupted when use Undo. Not sure if this can be a problem for more operators.
@Antonio Vazquez (antoniov) gpencil_paint.c has undo function but gpencil_primitive.c doesn't. This might be the cause.
Not sure what OPTYPE_UNDO does in this case.
@Charlie Jolly (charlie) No idea...this was old code done before I enter in GP project. If you can, try your ideas and maybe works.
@Charlie Jolly (charlie) For me fails always.
  1. Open 2D template
  2. Draw something
  3. Press L
  4. Press Ctrl+Z
  5. Crash
@Charlie Jolly (charlie) Proposed fix:
diff --git a/source/blender/editors/gpencil/gpencil_paint.c b/source/blender/editors/gpencil/gpencil_paint.c
index 06ff0e744b9..894fb6eced4 100644
--- a/source/blender/editors/gpencil/gpencil_paint.c
+++ b/source/blender/editors/gpencil/gpencil_paint.c
@@ -3460,12 +3460,18 @@ static int gpencil_draw_modal(bContext *C, wmOperator *op, const wmEvent *event)
   /* We don't pass on key events, GP is used with key-modifiers -
    * prevents Dkey to insert drivers. */
   if (ISKEYBOARD(event->type)) {
-    if (ELEM(event->type, LEFTARROWKEY, DOWNARROWKEY, RIGHTARROWKEY, UPARROWKEY, ZKEY)) {
+    if (ELEM(event->type, LEFTARROWKEY, DOWNARROWKEY, RIGHTARROWKEY, UPARROWKEY)) {
       /* allow some keys:
        *   - for frame changing [#33412]
        *   - for undo (during sketching sessions)
+    else if (event->type == ZKEY) {
+      if (event->ctrl) {
+        p->status = GP_STATUS_DONE;
+        estate = OPERATOR_FINISHED;
     else if (ELEM(event->type, PAD0, PAD1, PAD2, PAD3, PAD4, PAD5, PAD6, PAD7, PAD8, PAD9)) {
       /* allow numpad keys so that camera/view manipulations can still take place
        * - PAD0 in particular is really important for Grease Pencil drawing,
@Antonio Vazquez (antoniov) I've managed to finally reproduce the bug and your fix works.
I can commit the fix under my name but might be better for you to commit as it is your fix!
