Outliner, Visibility filter toggle doesn't show controls for armature bones to hide/unhide
Closed, ResolvedPublicTO DO
Operating system: Linux-5.2.6-arch1-1-ARCH-x86_64-with-arch 64 Bits
Graphics card: Radeon RX 550 Series (POLARIS11, DRM 3.32.0, 5.2.6-arch1-1-ARCH, LLVM 8.0.1) X.Org 4.5 (Core Profile) Mesa 19.1.4
Broken: version: 2.80 (sub 75), branch: makepkg, commit date: 2019-07-29 14:47, hash: rBf6cb5f54494e Arch Linux package
Worked: 2.79b
In outliner, enabling visibilty toggles only adds blank space near armature bones where I think there supposed to be a visibility toggles.
See attached GIF:
The behaviour hasn't changed between 2.7x and 2.80. However, it's certainly quite confusing:
Armature bones use a different flag what isn't per view layer - you must enable the Disable in Viewports toggle, which is equivalent to the old Hide toggle. But it still uses the eye icon.
@Zachman I guess it the bone toggles are using the wrong icons here at the very least. Also there's a missing depsgraph update when toggling this.
Ideally, you *could* change the Hide flag also for bones, and also be able to do it from any mode - would be good to simplify this.
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to Low.Aug 9 2019, 10:15 AM
Campbell Barton (campbellbarton) edited a custom field.
T68444 is the issue about the dependency graph update [was also stumbling over the icon/column issue there...]
Since these are so closely related, will assign @Zachman to both (feel free to throw back if this is not for you though...)
