Shortcuts with accents like ` or ´does not work on serveral languages.
I guess every except english language with accents have the same problem, cause it is a special char that needs another key after shift-accentgrave. Like shift-accentgrave gave nothing pressed until another key, for example a -> à. Or space for a ` alone. So the default shortcut in the keyboard map for "View Navigation (Walk/Fly)" does not work.
A accents shortcut also cannot be set in the preferences, for example a shift+` gives a "shift ]",
a shift+' gives a "shift /".
Changing the interface language to english, does not affect this.
Tested on Win7.
version: 2.80 (sub 75)
