Operating system: Windows-10 64 Bits
Graphics card: GeForce GTX 660 4.5.0 NVIDIA 416.94
Broken: version: 2.81 (sub 2), branch: master, commit date: 2019-08-18 20:41, hash: rB10001d909905, it dosent work in 2.8 too.
Worked: ?
Adding custom property to bpy.types.Spline will give error when writing value to it.
import bpy bpy.types.Spline.test = bpy.props.StringProperty(name="Dosent work", default="aa") bpy.types.Object.test = bpy.props.StringProperty(name="Works", default="aa") obj = bpy.context.active_object print(obj.test) #works obj.test = '123' #works print(obj.data.splines[0].test) #it should be string but gives <built-in function ... obj.data.splines[0].test = '123' #error
Open blend file and run script:
Using 'test' property on spline will fail.
