Operating system: Linux Mint 18.3
Graphics card: GTX 780m
Broken: 2.81 master d5192d6fd64959ccede2b9a0014f8b411dec225c 28/08/2019 17:44 +3GMT
Blender fails to link when OIDN is enabled producing the following error messages:
[100%] Building C object source/creator/CMakeFiles/blender.dir/buildinfo.c.o [100%] Linking CXX executable ../../bin/blender /opt/lib/oidn/lib/libOpenImageDenoise.a(device.cpp.o):device.cpp:function oidn::Device::commit(): error: undefined reference to 'tbb::interface7::internal::task_arena_base::internal_max_concurrency(tbb::interface7::task_arena const*)' /opt/lib/oidn/lib/libmkldnn.a(cpu_engine.cpp.o):cpu_engine.cpp:function mkldnn_status_t mkldnn_primitive_desc::create<mkldnn::impl::cpu::jit_avx512_common_convolution_fwd_t<(mkldnn_data_type_t)1, (mkldnn_data_type_t)1, (mkldnn_data_type_t)1>::pd_t>(mkldnn_primitive_desc**, mkldnn::impl::op_desc_t const*, mkldnn_primitive_attr const*, mkldnn_engine*, mkldnn_primitive_desc const*): error: undefined reference to 'tbb::interface7::internal::task_arena_base::internal_max_concurrency(tbb::interface7::task_arena const*)' /opt/lib/oidn/lib/libmkldnn.a(cpu_engine.cpp.o):cpu_engine.cpp:function mkldnn_status_t mkldnn_primitive_desc::create<mkldnn::impl::cpu::jit_avx512_common_convolution_winograd_fwd_t::pd_t>(mkldnn_primitive_desc**, mkldnn::impl::op_desc_t const*, mkldnn_primitive_attr const*, mkldnn_engine*, mkldnn_primitive_desc const*): error: undefined reference to 'tbb::interface7::internal::task_arena_base::internal_max_concurrency(tbb::interface7::task_arena const*)' /opt/lib/oidn/lib/libmkldnn.a(cpu_reorder.cpp.o):cpu_reorder.cpp:function mkldnn::impl::cpu::simple_reorder_impl<(mkldnn_data_type_t)1, (mkldnn_format_tag_t)1, (mkldnn_data_type_t)1, (mkldnn_format_tag_t)1, true, mkldnn::impl::cpu::spec::direct_copy_except_dim_0>::execute(mkldnn::impl::cpu::cpu_reorder_pd_t const*, float const*, float*): error: undefined reference to 'tbb::interface7::internal::task_arena_base::internal_max_concurrency(tbb::interface7::task_arena const*)' collect2: error: ld returned 1 exit status source/creator/CMakeFiles/blender.dir/build.make:425: recipe for target 'bin/blender' failed make[3]: *** [bin/blender] Error 1 CMakeFiles/Makefile2:6578: recipe for target 'source/creator/CMakeFiles/blender.dir/all' failed make[2]: *** [source/creator/CMakeFiles/blender.dir/all] Error 2 Makefile:162: recipe for target 'all' failed make[1]: *** [all] Error 2 GNUmakefile:292: recipe for target 'all' failed make: *** [all] Error 2
Full log is linked here: https://pastebin.com/JwtNPvBe
install_deps.sh completes successfully.
TBB (tbb2019_20190605oss_lin from github) is installed in /opt/tbb2019
Environment variables:
$PATH=/opt/tbb2019/include:/home/user/bin:/home/user/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin $LD_LIBRARY_PATH=/opt/tbb2019/lib/intel64/gcc4.7 $TBB_ROOT=/opt/tbb2019/
- Run install_deps.sh --with-oidn
- Compile blender using the command provided in the BUILD_NOTES.txt
- Build process stops at linking stage.
Building without OIDN works normally
