Operating system: Linux bertha 5.2.0-gentoo-bertha #1 SMP Sat Jul 13 21:34:03 EDT 2019 x86_64 Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz GenuineIntel GNU/Linux
Graphics card: Radeon Pro WX 9100 (VEGA10, DRM 3.32.0, 5.2.0-gentoo-bertha, LLVM 7.1.0)
Broken: 2.81 (sub 5), Tue Sep 3 21:45:39 2019 +0200 commit 1af0f1fed9a680df6cdde9c2b220b5ddc9bf03e0 HEAD -> master
Address Sanitizer reporting a read overrun of eight bytes of a buffer; aborts blender.
- Build a debug blender with Address Sanitizer enabled. i.e. 'make developer debug', specifically with cmake flag WITH_COMPILER_ASAN=ON
- Run blender. Address Sanitizer aborts on startup
- Run blender again. Now, preferably, in a debugger. See what's up (my notes on seeing what's up is below)
Blend file
Not triggered by a blend file - Can't get that far.
Address Sanitizer dump
Where the Plot Sickens
Stems from commit ee8f69c96cba62b083fb089432cddd0bce5d08e1
Author: Julian Eisel <eiseljulian@gmail.com>
Date: Tue Sep 3 15:43:38 2019 +0200
With that commit, a static const EnumPropertyItem file_action_types[] wm_operatorprops.c, line 81
lacking a terminating sentry record is defined and passed to RNA_def_enum(...) as an items buffer. See line 207, same file.
RNA_def_enum, failing to find the sentry record, reads past the buffer and Thus Offends The Address Sanitizer Gods.
To be picky, the overflow specifically takes place in rna_define.c:RNA_def_property_enum_items(...), called by RNA_def_enum(...)
See rna_define.c, line 1776
To keep RNA_def_property_enum_items(...) happy, methinks the enum file_action_type needs to be given a final sentry item filled with zero bytes. Template here:
rna_space.c line 419
@Julian Eisel (Severin), could you take a look, please. Take care!
