Operating system: Windows 10 x64 Pro (1809, ver 10.0.17763.720)
Graphics card: Nvidia GTX 1060
Broken: Tested with 2.80 Release and 2.81 (f3a4f12ac090)
In the VSE, the preview in the Video Sequencer window does not always show the correct video frame when navigating forth and back.
- Open this blend file:
- Drag the video mentioned below into the VSE
- Navigate to frame 551
- Navigate to frame 552. You see the image is different to frame 551.
- Navigate back to frame 551
Problem: After step 5, the preview still shows frame 552. You can step forth and back between 551 and 552 but the preview does not change even though it should.
I've uploaded the sample video. As I cannot publish it, I'd provide the link in a private message only.
Please note that the problem disappers if I shorten the video (by remuxing it in copy mode with ffmpeg and just changing the length).
I've narowed it down: If the video is longer than 5:51.60, the problem appears, otherwise it does not.
