When the Bump node is placed in a node-group, bump is not working.
{F7727044}Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 417.01
Broken: version: 2.81 (sub 8), branch: master, commit date: 2019-09-08 21:40, hash: rBf3a4f12ac090
Worked: (Blender 2.81 build September 04)
When the Bump node is placed in a node-group, bump is not working (as it should).
  1. Add a plane and give it a new material
  2. Add: bump node and a texture. Noise for example.
  3. Connect Noise texture (Fac) to height socket of bump node.
  4. Connect the normal of the bump node (out) to the normal (in) of principled BSDF).
This works. But now;
  1. Make a NodeGroup of the Bump node and the noise texture
  2. Connect this nodegroup with the prinicpled shader (normal and optionally Base Color).
Now there is no bump, and if you adjust the strength strange things are going on with the normals.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.Sep 10 2019, 10:19 AM
Normals do not behave normally if the bump node is within a node group. The Bump node has extra hidden code now. These hidden values are Height_dx and Height_dy.
Steps:
If you group a single bump node you can get these hidden Height values. Once grouped, the Height_dx/dy can be influenced outside the node. Even if it doesn't look like it's connected to anything.
Just adding more info
