Blender 2.81 — Shadow glitches with Workbench render-engine (in viewport and same at render)
Confirmed, NormalPublicKNOWN ISSUE
Graphics card: GeForce GTX 560/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
Broken: version: 2.81 (sub 9), branch: master, commit date: 2019-09-09 17:22, hash: rB6be3348505ce
Broken shadows "traced path" glithc effect in the air in places where geomety have "complex area" (when you use shadows from Workbrench render and same in viewport).
Screenshot
Here is on video uou can see it. Sorry for broken english.
Don't know how to reproduce it step by step, so I've put the file here:
Exact steps for others to reproduce the error:
  1. In New file turn on shadows in Solid draw mode.
  2. Add plane and scale it outside viewport clipping area
  3. You will see shadow glitch like this:
Thanks Michael. :)
To the developers: but in the file not only one shadow bug, but a couple another related too, I think. So check the file definitely
Germano Cavalcante (mano-wii) lowered the priority of this task from 90 to 50.
I can confirm, it seems to be related to the scale of the objects.
but in the file not only one shadow bug, but a couple another related too, I think. So check the file definitely//
Multiple requests is not allowed here. If you want to report anther problem, you should make separate bug report for this
Jeroen Bakker (jbakker) changed the subtype of this task from "Report" to "Known Issue".Jan 10 2020, 12:52 PM
Hmmm there was already a report for this issue. But cannot find it. It is a known issue, but don't think it will be tackled in the short term so I will set it to known issue.
Just a note but still happens in 2.83.1
In this scene something similar happens. Confirmed on Win10 with Blender 2.83.10 / 2.91.2, and on Win7 with Blenders: 2.83.10, 2.91.2, 2.92.0-213f8294b5c8 beta, 2.93.0-92b0803f35a7 alpha.
The glitch is seen on few frames here. And only in Solid viewport shading. It hides - if any 1 of 3 modifiers: Bevel, Array, Curve are disabled. And it disappears - when moving object, sometimes reappearing on other frame(s).
  • OS: Windows-10-10.0.19041-SP0 64 Bits, GPU: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
  • OS: Windows-10-10.0.18362-SP0 64 Bits, GPU: Intel(R) HD Graphics 4600 Intel 4.3.0 - Build 20.19.15.4531
  • OS: Windows-7-6.1.7601-SP1 64 Bits, GPU: Intel(R) HD Graphics 5500 Intel 4.4.0 - Build 20.19.15.5063
