Commandline render takes too long synchronizing objects in cycles
Closed, ResolvedPublicKNOWN ISSUE
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.60
Commandline render takes a big amount of time synchronizing all objects in scene.
It seems to be just a matter of taking too long to actually PRINT the log to console, as per https://developer.blender.org/T62833.
  • Factory settings
  • Create 3000 cubes (separate objects)
  • Set engine to Cycles
  • Save file
  • Press F12, just for cientific purposes. Buckets should start immediately.
  • Close Blender and run a command line frame render. Here is what I used:
cd %blender%
blender -b "path\file.blend" -f 0
It should take several seconds to synchronize from Cube to Cube.3000 prior to actually start rendering.
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 30.Sep 19 2019, 3:50 PM
Please prepare a .blend file so that everyone can reproduce the issue using the same file.
Sure! Here it is!
It's a file set for Cycles rendering with 3000 cubes.
Again, the command used for rendering was:
cd %blender%
And, as per bug report mentioned above, it seems to occur on Windows only
Jacques Lucke (JacquesLucke) raised the priority of this task from 30 to 50.Sep 19 2019, 4:25 PM
Can confirm the issue. The syncing takes about 20s for me when its printing to the Powershell on windows. Without the printing it is done in less than a second.
Maybe there should be a command line option to disable the printing? Or maybe it is faster to log everything to a file instead? I don't know what the best solution to the problem is.
I guess a single print of "Synchronizing objects" could be sufficient for a normal situation.
And if you need a print for each object (to see which one is taking too long, for example), one could enable a debug mode or raise the verbosity level up a notch.
Brecht Van Lommel (brecht) changed the subtype of this task from "Report" to "Known Issue".Jan 27 2020, 12:01 PM
Thomas Dinges (dingto) closed this task as Resolved.Nov 24 2022, 4:36 PM
Thomas Dinges (dingto) claimed this task.
Cannot confirm this anymore with Blender 3.4, total render time is 00:08.71.
