Graphics card: Radeon RX 590 Series ATI Technologies Inc. 4.5.13547 Core Profile Context 25.20.15027.9004
Broken: version: 2.81 (sub 12), branch: master, commit date: 2019-09-19 20:35, hash: rBc8df6f2cf9df
Worked: 2.80 official release works fine with same .blend file.
In 2.81 latest version the environment map for world does not show up in render view and when you rotate the scene images pile up. I have screenshots. It works fine in 2.80 if you load the same blend file. If you go back with the same blend file in 2.81 exactly same problem shows up. I also include screenshots of both versions.
Just the default cube, add an environmental texture to world, a vector mapping node left to it.
