Node Editor - invisible and disappering connections
Closed, DuplicatePublic
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 430.86
Broken: version: 2.81 (sub 12), branch: master, commit date: 2019-09-25 20:42, hash: rBee4707544904
2.80
In Node Editor there is a problem with connection lines: they are not shown or disappear when reconnecting other nodes
This problem appears when Blender uses non-default user startup file, as I have investigated so far.
Cause even after Load defaults then Save config and reopen Blender ( it starts with my startup file ) does not solve this problem.
I think that is something not right if user have to rebuild his workplace from scratch every time when software is updated.
Please investigate this case. Thank you.
I would like to add that the physical connection is active.
Just the line disappears and is not displayed. But connection works.
If you will try disconnect that "invisible" wire then you will see this wire partially disconnected and sicked to the cursor as should be ( but when connecting nodes was invisible)
