Connect Vertex Path creates duplicate edge and face
Closed, ResolvedPublicBUG
Operating system: Linux
Graphics card: GTX 1070
Broken: 2.80
Worked: -
related to https://developer.blender.org/T70286
Connect Vertex Path creates duplicate edge and face in special case
Based on the default startup:
  1. select 3 parallel edges of the cube and do X->Edge Collapse
  2. select one of the remaining two quads and press Ctrl+T to triangulate
  3. select the newly created edge in vertex select mode and press J to connect vertex path
you should be left with a duplicate edge and a duplicate face
Germano Cavalcante (mano-wii) lowered the priority of this task from 90 to Low.
With the first step you already create a mesh with duplicated face.
This mesh is not invalid as these situations are indeed allowed.
But it is good to prevent this from happening when possible.
Germano Cavalcante (mano-wii) changed the task status from Duplicate to Unknown Status.Sep 27 2019, 7:18 PM
Oops I did the other way around
