Operating system: Ubuntu 18.04.3 LTS (Bionic Beaver)
Graphics card: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] (rev a1)
Broken: blender-2.81-ed779333bb82 to current
Worked: blender 2.80 release version
When using the "Position" output from the "Geometry" node for textures the "Bump" node does not output a normal map based on the bump map.
This "Position" output also doesn't work with the "Displacement" node.
- Select cube.
- go to the "Shader Editor".
- delete "Principled BSDF" node.
- Add a "Geometry" node.
- Add a "Noise Texture"
- Connect the "Position" output of the "Geometry" node into the "Vector" input of the "Noise Texture" node
- Add a "Bump" node.
- Connect the "Fac" output of the "Noise Texture" node into the "Height" input of the "Bump" Node.
- Connect the "Normal" output of the "Bump" node into the "Surface" input of the "Material Output" Node.
Edit: You can switch out the Bump node for a "Displacement" node and there will be no bumps displacement texture.
