Blender 2.81 Alpha on macOS 10.14.6 crashes upon launch starting with ff10ff782bde
Operating system: Darwin-18.6.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel HD Graphics 4000 OpenGL Engine Intel Inc. 4.1 INTEL-12.9.22
Broken: version: 2.81 (sub 12), branch: master, commit date: 2019-09-30 22:45, hash: rBff10ff782bde
Blender 2.81 Alpha on macOS 10.14.6 crashes upon launch, starting with ff10ff782bde, 60a827a2a991 has it too. The crash.txt contains:
backtrace
0 blender 0x000000010e684e67 BLI_system_backtrace + 55
1 blender 0x000000010e3a724a sig_handle_crash + 362
2 libsystem_platform.dylib 0x00007fff596b1b5d _sigtramp + 29
3 ??? 0x0000000000000000 0x0 + 0
4 blender 0x000000010e3fe31a blo_do_versions_280 + 25786
5 blender 0x000000010e3bb3b5 do_versions + 245
6 blender 0x000000010e3ae39e blo_read_file_internal + 6734
7 blender 0x000000010e3a7f1d BLO_read_from_file + 61
8 blender 0x000000010e45a297 BKE_blendfile_read + 71
9 blender 0x000000010e8b8da9 wm_homefile_read + 2009
10 blender 0x000000010e8c101a WM_init + 346
11 blender 0x000000010e3a39c5 main + 757
12 libdyld.dylib 0x00007fff594c63d5 start + 1
Just try launching the application. Double clicking it in the Finder or even in the Terminal using /Applications/Blender.app/Contents/MacOS/blender --factory-setup
Bastien,
This morning I downloaded the most recent Daily Build, version rB0812949bbc3d and found that it had the exact same problem. I tried launching it using the Terminal with a --factory-setup, still crashed right upon launching.
But when I take the macOS route and delete:
~/Library/Application Support/Blender/2.81
The Daily Build opens up again! So the --factory-setup doesn't delete those preferences and settings files and give Blender a true factory settings clean start.
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Jan 14 2020, 12:12 PM
@Anton Raves (Memento) Is this still an issue with latest build? https://builder.blender.org/download/
I do not think it is a bug but activating Blender its factory-setup does not go far / deep enough, it does not delete preference files. Back then Blender crashed and kept crashing, until I manually deleted the Preferences folder for Blender.
Yes --factory-startup is temporary parameter. If you want pernament action, you have to delete them manually or save and overwrite from factory startup. But that's besides the point.
I am asking if you (by any chance) have still same problem with latest build.
With the current beta 2.82 and macOS 10.15.2 Catalina I have not had the problem yet, no...
Richard Antalik (ISS) closed this task as Archived.Jan 15 2020, 9:16 PM
Richard Antalik (ISS) claimed this task.
Thanks for info.
