Graphics card: GeForce GTX 1070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.36
Broken: version: 2.81 (sub 12), branch: fluid-mantaflow, commit date: 2019-09-27 09:45, hash: rB114783000d0b
[Trying to copy one Mantaflow 'flow' object setup using ctrl+l linking, the modifier comes across, but does not bring the keyframes that had been set on the 'density' parameter.
All the copied Mantaflow modifiers came over with a density of zero, and basically did not emit.]
[Open the attached blend, select the 'A_FirstShard' object and you should see keyframes in the graph editor for Density.
right-click the 'BrokenCube' collection in the Outliner and chose 'select objects', then in the 3D view hit ctrl+l and chose modifiers.
You should get Mantaflow applied to all the other shard objects, but with a density of zero, rather than the density ramping down from one to zero. If it behaves like it does for me that is.]
