Viewport and Icons disappear after recent commit rBc6018391765c
Closed, DuplicatePublic
Operating system: macOS 10.14.6 on i7
Graphics card: AMD M395X 4Gb
Broken: c6018391765c
Worked: 12688a6636da
When working in viewport, objects and icons disappear
To track this issue down I've compiled a lot of versions to narrow it down.
This commit is causing the issue.
What I did to test is:
start blender
switch to top ortho
add curve->circle
go into edit mode
scroll (zoom) in/out
go into object mode
Observe if Object/Icons disappear
Thanks for looking into it,
Roel
Roel Koster (kostex) created this task.
Like you've requested I've assigned it to you myself
Thanks
Germano Cavalcante (mano-wii) lowered the priority of this task from 90 to 80.Oct 11 2019, 7:03 PM
Clement,
Just downloaded a version from the buildbot instead of my own.
Same thing happens..
Started to think about it.. I had never tried this with factory default settings.
It seems that the behaviour is not shown when starting fresh. Maybe it has to do with some setting I've set that triggers this.
I'm going through them all now.
Is there anything (setting) you can think of that could trigger the disappearance of those icons and objects? Especially in regards to the patch?
Would help me out a lot to pinpoint why it happens
After testing every single option I have disabled/enabled it comes down to the preference setting: Auto Depth
(use_mouse_depth_navigate) Enabling it causes the objects and icons to disappear after zooming in/out a couple of times
Hope this helps
I think this was the same issue that T71147. Can you confirm that with latest master or next 2.82 buildbot build?
Hi Clément,
thanks for linking the issue to my report. You were right to do so!
I've updated/compiled blender right away and after a factory default, I can no longer reproduce my issue, so thanks very much!
Regards,
Roel
