Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.48
Broken: version: 2.81 (sub 15), branch: master, commit date: 2019-10-11 19:43, hash: rB60d02b336eaf
In 2.80 you can switch outputs of Nodes with the Node Wrangler CTRL+Shift+Left Click shortcut to easily switch between each one, in 2.81/2.82 you can't has before, you have to deselect the node, then CTRL+Shift+Left Click again to switch to the next output.
Open 2.80, add a shader node with outputs, use the Node Wrangler to switch outputs, then try to do the same in 2.81/2.82.
