2.81 eevee - Alpha clip/Alpha hashed causes visual glitches when exporting PNG with Alpha
Closed, ResolvedPublicBUG
Operating system: Windows-10-10.0.14393 64 Bits
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86
Broken: version: 2.81 (sub 15), branch: master, commit date: 2019-10-12 15:33, hash: rB95f020c853d6
Worked: version: 2.81 (sub 14), branch: master, commit date: 2019-10-09 07:42, hash: rB40a55be82cf5
When geometry that has transparency with either Alpha clip or Alpha hashed, intersects other objects, the intersection borders create these black dots that only appear when file is exported with RGBA
This only happens in EEVEE, this problem does not occur in cycles
-default blender file (eevee)
-duplicate cube and shift it to side so that both intersect
-change second cube's material alpha value to 0, and set blend and shadow mode to alpha clip/alpha hashed
-Render (you should notice that only first cube appears in image viewer w/o any apparent problem)
-Save image as > PNG with RGBA
-Open that image and notice that there are visual artifacts where both objects should be intersecting
ps:This effect is even more apparent if there's camera motion blur present
Vas (Alumx) edited projects, added BF Blender (2.81), Eevee; removed BF Blender.
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 50.Oct 14 2019, 4:27 PM
I can reproduce it I think. It would be helpful if you could provide the simple .blend file. Just to make sure we are testing using the same scene.
Vas (Alumx) updated the task description. (Show Details)Oct 14 2019, 4:32 PM
@Jacques Lucke (JacquesLucke) There ya go! I updated the task with .blend file included
Clément Foucault (fclem) raised the priority of this task from 50 to High.Oct 16 2019, 9:25 PM
