Shift R problem
Closed, DuplicatePublic
Graphics card: Intel(R): No
[Shift R does not work how it should ]
[when i use the command Shift R it should duplicate an object and move away from it in a determined distance, but it this command just do a copy of the object overlapping the original object]
Works fine here. Sound like a user error, though I can't off the top of my head think of why it would behave like that.
Demeter Dzadik (Mets) changed the task status from Unknown Status to Archived.Oct 16 2019, 12:34 PM
Demeter Dzadik (Mets) claimed this task.
Shift+R is not specific enough since I'm pretty sure it does different things on different keybinds.
I'm assuming we're talking about Repeat Last operator. And it does what it says. If you duplicate an object and move it a determined distance, then do Repeat Last, it will duplicate an object and move it a determined distance. (this is what you want to do)
If you duplicate an object then cancel moving it, then do Repeat Last, it will duplicate an object in place. (this is what you're doing)
At least that's my take on it, and I'm pretty sure this is what's happening, so closing this because no bug here.
