Compositor Interactions/Selections fail on dual monitors
Operating system: Darwin-17.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon HD - FirePro D700 OpenGL Engine ATI Technologies Inc. 4.1 ATI-1.68.23
Broken: version: 2.82 (sub 0), branch: master, commit date: 2019-10-11 12:13, hash: rB533a7e25dbdb
When two compositor windows are open on different monitors, interactions do not work as expected:
https://youtu.be/ppWJGllv3A8
For example, when interacting with nodes, click and drag (move) doesnt work when on separate monitors, but when both windows live on the same monitor, the problem no longer exists (see video example).
Open a compositor project, duplicate the blender (compositor) window, duplicate to a separate monitor and you can no longer click and drag nodes.
Related Objects
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Jan 14 2020, 9:21 PM
Is this still an issue with latest build? https://builder.blender.org/download/
michael campbell (3di) changed the task status from Needs Information from User to Needs Triage.Jan 14 2020, 9:47 PM
yes just tested. You can only interact with the compositor nodes on the duplicate window in the second monitor.
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from Developers.Jan 14 2020, 10:42 PM
Issue is also happening on windows 10
Jacques Lucke (JacquesLucke) changed the task status from Needs Information from Developers to Needs Information from User.Jan 21 2020, 11:42 AM
I cannot reproduce it on Ubuntu 19.10 and Windows 10 in the default file just with "Use Nodes" enabled in the Compositor.
Can you reproduce it in any file? Please prepare a as-simple-as-possible example file in which you can reproduce it.
Dalai Felinto (dfelinto) closed this task as Archived.Feb 6 2020, 3:39 PM
Dalai Felinto (dfelinto) claimed this task.
Note: The issue you have may be because of Blender not auto-focusing on the windows. You need to click on them before being able to edit things there. I couldn't tell from your video.
