UV editor overlays not working properly on MacOS
Closed, DuplicatePublic
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits (MacOS Mojave 10.14.6)
Graphics card: AMD Radeon Pro 555X OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.20
Hardware: MacBook Pro 15-inch 2019
Broken: version: 2.81 (sub 15), branch: master, commit date: 2019-10-15 17:59, hash: rBcfb6ffd48f77
Broken: version: 2.80 (official release)
Worked: https://twitter.com/PabloVazquez_/status/1184951697015234560
Edge overlays in the UV Editor seems to be broken here and the default thickness is hard to work with on a retina display.
I was advised that a "white" or "black" overlay should make it thicker, and it barely affects it.
  • Open Blender
  • have a mesh with a material and UVs, in edit mode
  • Go to the UV editor and show the current UV map
  • In the display panel, click the various "display as" options under "Overlays". Change is barely visible.
Note: in the system preferences, the "line width" setting doesn't seem to affect it either.
See attached screenshot.
Thanks a lot !
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Jan 15 2020, 3:29 PM
I have tested line thicness in preferences - now it does have an effect.
Can you tell us what DPI your monitor has?
Not sure if there were any other improvements, can you re-test with latest build? https://builder.blender.org/download/
UV lines and 2D cursor are always 1px width, even UI Scale has no effect.
Graphics card: AMD Radeon Pro 455 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.21
Broken: version: 2.83 (sub 0), branch: master, commit date: 2020-01-10 17:32, hash: rB01d9a2f71b56
With HiDPI display.
Richard Antalik (ISS) changed the task status from Needs Information from User to Needs Information from Developers.Jan 15 2020, 8:27 PM
Thanks for info.
