multisubresolution
Operating system:
Graphics card:
Blender Version 2.80{F7867214}
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Short description of error: model apear bugs on multisubresolution
Exact steps for others to reproduce the error wan i meke a new level or loding its hapening{F7867224}
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Unknown Status.Oct 29 2019, 12:57 PM
It is not clear what is happening here.
I can subdivide the trovão corpo object to level 6 without problems for example.
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, ... (it is best to use Help > Report a Bug from within blender here, this way system information is filled out for you already...)
  • then be more specific to the actual problem:
  • Do you get a crash? (you might be running out of RAM)
  • If you are getting artifacts, this might be related to T58473
Will have to close this report, please submit a new one.
