Border Rendering ignores Compositing
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 431.86
The Border Rendering ignores the Compositing when Render an animation. (ctrl f12)
Make a Border-Render (ctrl. B) and then hit render. In the compositing use a "Alpha over"- node
and put the Render-Node in the under socket. In the compositing you see, the Border-Render over
the color you choosed in the Alpah-over-node. But when you want to render the animation, in the
output will be everything black (no alpha) or white (with alpha) beside the border-render-part of the image.
The compositing gets clearly ignored when rendering an animation.
Philipp Oeser (lichtwerk) closed this task as Archived.Jan 8 2020, 7:11 PM
Hi and thx for the report (sorry this took some time to get answered...)!
Compositing still takes place [inside the render region].
Outside the render region, the frame gets filled with transparency by design.
https://docs.blender.org/manual/en/dev/render/output/settings.html
... renders a transparent background around the render region
So while what you describe might be useful in some cases it is still working as expected and not a bug [and there are other ways to do this].
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
