Graphics card: GeForce GTX 680/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.08
Broken: version: 2.80 (sub 75), branch: octane2019, commit date: 2019-09-28 20:52, hash: rB0cfcf0f74f76
I wrote to you to tell you that the GTX680 in my machine wasn't working with Octane. I have also had a problem getting the transmision slider to work when in Cycles while also using the GPU for rendering. As you know the transmision slider does nothing when the 'Metalic' slider is in use so I turn it off the set a value of 1.450 in the IOR and set the Transmision slider all the way up and that should give me Glass. However when using the GPU I get a really knarly looking black mess. OK that sounds like my GPU again. HOWEVER! when I take the new Principled BSDF shader out of the node tree alltogether and replace it with a simple Glass BSDF it works without issue. This means that my GPU is quite capable of working with Cycles and I'm guessing Octane as well. There must be a BUG.
Just thought I'd flag this.
John
