Mesh gets transparency in a specific vertex group after trying to render in EEVEE
Operating system: Windows-7-6.1.7600-SP0 64 Bits
Graphics card: Gallium 0.4 on llvmpipe (LLVM 3.8, 128 bits) VMware, Inc. 3.3 (Core Profile) Mesa 11.2.0 (git-aa91c51)
Broken: version: 2.80 (sub 75), branch: master, commit date: 2019-07-29 14:47, hash: rBf6cb5f54494e and 2.81 beta eba4a4bd73ba date 2019-11-15 16:32
Mesh gets transparency in viewport view in a specific vertex group after trying to render in EEVEE. this happened me in two models that were created in b3d 2.79b. in 2.80 this doesnt seem to appear but i havent check it out if thats correct...
some screenshots
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Nov 19 2019, 1:10 PM
.blend file is missing, please upload here
  • every check is helpful, so if you can confirm these load fine into 2.80, please provide that information as well
  • also make sure to check GPU requirements and up-to-date drivers
https://www.blender.org/download/requirements/
https://docs.blender.org/manual/en/dev/troubleshooting/gpu/index.html
added model link i hope that helps
Philipp Oeser (lichtwerk) raised the priority of this task from 30 to 90.Dec 5 2019, 3:28 PM
Not sure we support these kinds of glitches over VMWare, but yes, needs another look, thx for getting back...
Jacques Lucke (JacquesLucke) changed the task status from Needs Triage to Needs Information from User.Jan 15 2020, 4:16 PM
Do I read that correctly, the issue only happens on meshes that were created before in 2.79, but does not happen on any new model?
Does the issue still exist?
yes though i discovered that the issue was caused by opengl it self, i am using a opengl32.dll thats how i fortunately i can open blender 2.8, and sadly runs slower than 2.79b its runs smooth instead! also this was stupidly solve by deleting all materials in material tab by the way... this happened too with two object created in 2.8 that i joined and same shit happened and the solution was the same...i dont find a way to upgrade windows right now to see if i can update my drivers card..
Evan Wilson (EAW) closed this task as Archived.Jan 21 2020, 10:44 AM
Evan Wilson (EAW) claimed this task.
Thanks for the reports.
You are running Win 7 SP0 on an Ironlake (Arrandale) CPU with a software rasterizer from 2016.
This GPU is below the minimum requirements for Blender, so we no longer provide support for it.: https://www.blender.org/download/requirements/
Installing the latest graphics driver sometimes helps to make such GPUs work, see here for more information. https://docs.blender.org/manual/en/dev/troubleshooting/gpu/index.html
If that doesn't help, you can use Blender 2.79: https://www.blender.org/download/previous-versions/
