Exported FBX with animation problem
Operating system: Windows-10-10.0.14393 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.12
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-11-20 14:27, hash: rB26bd5ebd42e3
I exported an FBX with multiple object and animation but the actions are not all exported
attached my original blend file and exported FBX (Robot walk1.blend , Robot walk1.fbx)
also a basic blend file and FBX with only 2 objects inside (fbxbug.blend , bug.fbx)
import the FBX and compare it to the original blend file
Hello,
Importing the attached Robot walk1.fbx into Blender indeed shows a different animation than what is seen in Robot walk1.blend.
However, when I exported a new .fbx file from Robot walk1.blend and reimported it into Blender, the animation was identical to the initial blender file.
The same happened with the provided bug.fbx and fbxbug.blend.
Digging a bit further, I then exported your blender scene to .fbx with default settings. Reimporting it, I got the problem you mention, the animation was weird.
This then might not be a bug, but simply a case of not using the correct settings. To get the correct result, disable NLA Strips and All Actions when exporting to .fbx. I'm attaching an exported .fbx to show that it works.
Eitan Traurig (EitanSomething) changed the task status from Needs Triage to Needs Information from User.Apr 30 2020, 5:37 PM
Is this still an issue with 2.83?
Rouault Basile (RBasile) closed this task as Resolved.May 16 2020, 6:07 PM
Rouault Basile (RBasile) claimed this task.
No we can close it
