Batch Rebame 2.81 Missing?
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
The "Batch Command" is missing,in 2.81 release is very important command and usefull, please add again.
This doesn't appear to be a bug. The Batch Rename was added in 2.81, while the Blender version you are using is a 2.80 alpha version from one year ago. It's the most simple logic that the previous release doesn't have all the features that a new release has.
This report does not contain all the requested information, which is required for us to investigate the issue. Be sure to provide system information, Blender version, and a .blend file with exact steps to reproduce the problem.
You can try File->Defaults->Load Factory Settings. Also make sure mouse is over outliner region when you use shortcut.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 30.Nov 26 2019, 11:59 AM
Working fine here in 2.81 release.
  • How are you trying to call this? (should be Ctrl+F2 for blender keymap or Alt+Return for industry compatible keymap...)
  • If these still dont work, please try this with File->Defaults->Load Factory Settings (as @Anthony Edlin (krash) )already suggested...)
Please report back if this fixes it for you...
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Unknown Status.Dec 5 2019, 3:47 PM
