(Blender 2.81) Hair particles disappear in strip mode
Operating system: Microsoft Windows 10 Pro
Graphics card: AMD Radeon Graphics Processor
Broken: version: 2.81 (sub 16), branch: master, type: Release
Worked: 2.80
I installed the newest blender (2.81), and so far it seems amazing, but one thing irks me. In Eevee, the hair particles only work in strand mode. When I try to use strips, they disappear completely. Is there a solution to this issue?
Set "Render Engine" to "Eevee"
Add hair particle system to mesh object
Set "hair type shape" to "strip" under "Hair" in "Render Properties"
EDIT: I ran the Blender via the "blender_debug_gpu_glitchworkaround" command script, and the hairs were able to display as strips. However, I still need to know how to make them work when I run the program from the default executable. I'll provide the debug output.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 80.Nov 27 2019, 11:40 AM
@Clément Foucault (fclem): I can see lots of
GPUShaderInterface: Warning: Uniform XXX not found!
Anything we can do here?
That's what I'm wondering myself. The problem is fixed temporarily when I run "blender_debug_gpu_glitchworkaround", but I'm just wondering how that can be fixed for good.
The uniform warning is just a warning. It's harmless.
I cannot reproduce on Linux+Intel/Nvidia. Maybe @Jeroen Bakker (jbakker) can repro on AMD+windows.
Richard Antalik (ISS) changed the task status from Needs Information from Developers to Needs Information from User.Jan 16 2020, 4:28 PM
Can not reproduce on AMD+windows
Is this still an issue with latest build? https://builder.blender.org/download/
I don't know. Let me see.
UPDATE: Yep. the problem still persists.
What is the "blender_debug_gpu_glitchworkaround", also did you update your graphic card drivers?
Aaron Carlisle (Blendify) claimed this task.
Hi, Has this been solved, cuz i'm getting the same problem and i need answers, thank you!
I wasn't able to reproduce bug in first place, so I don't know if there is anything to be fixed.
Please make sure your GPU drivers are up to date, download latest Blender version https://builder.blender.org/download/ and click on File > Defaults > Load Factory Settings
If you have problems after these steps create new bug report.
i feel dumb, i had this exact same problem, had the exact same graphics card, and the exact same issues as in this post: it used to work for me in 2.8 but no longer after 2.81, all i had to do to fix this for good, was to update my graphics card but i never thought of it until i read about it here, thank u all! i appreciate what u do.
edit:
and i guess yes, resolved.
