Objects won't display in viewport
Operating system: OSX 10.15.1
Graphics card: Radeon Pro 560 4 GB, Intel HD Graphics 630 1536 MB
Broken: 2.81 (2.81 2019-11-20)
Objects become hidden and I cannot get them back.
It is unclear what steps caused this, but it seems to coincide with using particle generator on an object. I have several objects, all marked visible in the hierarchy. Only a couple of them are appearing. I cannot get the others to show. However, if I go to another tab (like Shading), the objects appear in the viewport.
WORKAROUND: If I split the viewport, the new version DOES show the objects. I can then join the viewport back and the objects are back.
Evan Wilson (EAW) lowered the priority of this task from 90 to 30.Nov 29 2019, 2:29 PM
This appears to be a duplicate of T71147 which was patched yesterday.
Mind checking if todays fresh build resolves the issue for you? https://builder.blender.org/download/
Hi. I tried this on yesterday's build (2.82 Alpha 2019-11-28). Still an issue. You can easily see it with the file I included. If you open it, there are only 2 objects that will show up in the viewport, and as you can see here are many more. If you split the viewport, the new version will show the other objects.
Evan Wilson (EAW) changed the task status from Unknown Status to Unknown Status.Nov 29 2019, 6:56 PM
Evan Wilson (EAW) claimed this task.
You are in Local View.
https://docs.blender.org/manual/en/latest/editors/3dview/navigate/views.html
Press / on the number pad and all your objects will appear.
Thank you for your report, closing.
