Wrong description in Grid Fill error notification
Closed, ResolvedPublicBUG
Irrelevant (I think)
Blender 2.81
The description of the error notification in the case of closing a hole with Grid Fill seems like it belongs to a different command. It tells the user to select two edge loops (like for Bridge Edge Loops tool), instead of asking the user to select a geometry with an even number of vertices (the notification shows when the selected geometry has an odd number of vertices, and so Grid Fill can't possibly close it, as it uses quads).
  1. Select any closed loop that has an odd number of vertices (Edit Mode).
  2. Execute Grid Fill command.
  3. Notification will pop up.
Yes in the code, when there is a single edge loop with even number of edges, then it smartly tries to split it into two edge loops. If there is odd number then it skips splitting and reports that you need two edge loops. Instead it should report that you need even number of edges in a single edge loop. Confirmed, but low priority.
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to Low.Dec 2 2019, 12:53 PM
Sybren A. Stüvel (sybren) changed the subtype of this task from "Report" to "Bug".Jan 20 2020, 2:15 PM
This sounds like a "quick hack" that I should be able to do. Can I have this as a way of getting my feet wet with Blender development?
