Blender 2.8 crashes while compiling scene
Operating system: Mac Catalina 10.15.1
Graphics card:
Radeon Pro Vega 20 4 GB
Intel UHD Graphics 630 1536 MB
Broken: Version 2.81a (2.81a 2019-12-04)
Worked: 2.79
I have created a blend file. The total animation is about 450 frames long.
When I start to animate sequence using cycles the animation randomly quits in 30-50 frames
Open the attached blend file
lava_E5_s6_lavaChambers_Lava280_WCollision_working.blend
Set the frames to start at 250 and end 445
[you will probably have to change where the files are stored]
Render Animation
[last time I ran this it stopped at frame 297]
[here is a complete dump]
Related Objects
Germano Cavalcante (mano-wii) lowered the priority of this task from 90 to 30.Dec 18 2019, 2:21 PM
Germano Cavalcante (mano-wii) updated the task description. (Show Details)
There is no .blend file attached
I have uploaded the blend file
Germano Cavalcante (mano-wii) raised the priority of this task from 30 to 90.Dec 19 2019, 2:18 PM
Jacques Lucke (JacquesLucke) changed the task status from Needs Triage to Needs Information from User.Dec 29 2019, 2:27 PM
Please try to simplify the file. Also it would be nice if you could make it work in Blender 2.82 (the fluid simulation system has changed). Not sure if the simulation is responsible for the crash, maybe you can just remove it for the sake of the bug report.
I rendered up to frame 330, but did not get a crash yet. I also removed the sample count to make it render faster.
Dalai Felinto (dfelinto) closed this task as Archived.Jan 13 2020, 6:16 PM
Dalai Felinto (dfelinto) claimed this task.
