UDIM: filling a secondary tile with a generated image before you fill the first tile wont actually fill the tile
Operating system: Linux-5.3.12-200.fc30.x86_64-x86_64-with-fedora-30-Thirty 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.31
Broken: version: 2.82 (sub 5), branch: master, commit date: 2019-12-17 10:39, hash: rBbda4a284d201
Worked: never
UDIM: filling a secondary tile with a generated image before you fill the first tile wont actually fill the tile... you have to fill the first tile to actually see anything...
  • Open file
  • In the Image Editor > Image Tab (sidebar) > UDIM Tiles panel you should see two tiles [1001 and 1002]
  • both tiles are not filled yet
  • select the 1002 tile (should be selected already)
  • execute the Fill Tile operator
  • UDIM token is added to the tile, but it is not filled
This was already mentioned in T72487: UDIMs: Loss of texture information after saving., but reporting here separately as requested by @Lukas Stockner (lukasstockner97).
Note this already had an answer there:
is expected, but should be communicated better, probably by disabling the tile operators until the first tile is filled
Philipp Oeser (lichtwerk) renamed this task from UDIM: filling a secondary tile with a generated image before you fill the first tile wont actually fill the tile... you have to fill the first tile to actually see anything... to UDIM: filling a secondary tile with a generated image before you fill the first tile wont actually fill the tile.Dec 17 2019, 2:34 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to Low.
Philipp Oeser (lichtwerk) created this task.
Currently it isn't possible to fill the second tile without filling the first tile. Should we close this one?
Philipp Oeser (lichtwerk) closed this task as Resolved.Jan 13 2020, 2:42 PM
Yeah, rB850aa3a6cfe1: Image Editor: Disable tile operators if tile 1001 is missing was committed after this report was created, so.... guess it could be closed.
