Graphics card: Intel(R) Iris(TM) Pro Graphics 5200 Intel 4.3.0 - Build 20.19.15.4549
Broken: version: 2.82 (sub 6), branch: master, commit date: 2019-12-27 20:38, hash: rBc2a37867f21b
The io_scene_fbx addon returns an error when trying to import a fbx file. Opening the same file with 2.81a is working fine. The error Only occurs with fbx file which have texture embed in it. Here is the TraceBack :
File "c:\Tilapiatsu\05_portable_app\Blender_2.82\2.82\scripts\addons\io_scene_fbx\__init__.py", line 217, in execute
if import_fbx.load(self, context, filepath=path, **keywords) == {'FINISHED'}:
File "c:\Tilapiatsu\05_portable_app\Blender_2.82\2.82\scripts\addons\io_scene_fbx\import_fbx.py", line 3153, in load
_(); del _
File "c:\Tilapiatsu\05_portable_app\Blender_2.82\2.82\scripts\addons\io_scene_fbx\import_fbx.py", line 3145, in _
ma_wrap.alpha_texture.copy_from(ma_wrap.base_color_texture)
File "c:\Tilapiatsu\05_portable_app\Blender_2.82\2.82\scripts\modules\bpy_extras\node_shader_utils.py", line 626, in copy_from
self.image = tex.image
File "c:\Tilapiatsu\05_portable_app\Blender_2.82\2.82\scripts\modules\bpy_extras\node_shader_utils.py", line 36, in wrapper
return func(self, *args, **kwargs)
File "c:\Tilapiatsu\05_portable_app\Blender_2.82\2.82\scripts\modules\bpy_extras\node_shader_utils.py", line 702, in image_set
image.colorspace_settings.name = self.colorspace_name
TypeError: bpy_struct: item.attr = val: enum "Non-Color" not found in ('AppleP3 Filmic Log Encoding', 'AppleP3 sRGB OETF', 'BT.1886 EOTF', 'BT.1886 Filmic Log Encoding', 'Filmic Log Encoding', 'Linear', 'Non-Colour Data', 'sRGB OETF')Exact steps for others to reproduce the error
- Open Blender
- Click on File - Import - FBX
- Select the FBX on the browser
- ERROR
You can use the provided fbx file to reproduce the issue
Thanks for your help
