Auto Merge > Split Edges & Faces: Doesn't split faces
Closed, ResolvedPublicKNOWN ISSUE
Graphics card: GeForce GTX 1660/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.41
Broken: version: 2.82 (sub 6), branch: master, commit date: 2019-12-30 18:20, hash: rB56ef761381ec
"Split Edges & Faces" doesn't split faces as expected when the other geometry already has a face.
  1. Add a plane.
  2. In Edit Mode, activate "Auto Merge" and "Split Edges & Faces". Threshold = 0.001 m
  3. Extrude any edge towards the center of the plane.
It doesn't split the first plane.
It's not a bug, just a limitation. The upcoming "Destructive Extrude" does it better.
Eduardo (massanet) added a comment.EditedJan 1 2020, 3:03 PM
"Extrude" was just the simplest way I found to show the bug.
This same behavior can be seen if you get any other plane and intersect coplanar with the first.
It merges and splits edges as expected, but faces remain duplicated and not splitted.
I was always aware that it didn't split the faces but didn't think it was a bug (cause I'd always mistaken the operator as "Split The Edges" only, ๐Ÿ˜…). My bad, ๐Ÿ˜…. Yes, It is a bug and has been around from the beginning.
Thanks for the report.
This is a known limitation.
I have plans to implement a solution that solves this case but is not that simple.
And it's not the priority right now.
Anyway, this is not a bug as the mesh is still valid (no duplicate faces).
So closing.
Germano Cavalcante (mano-wii) reopened this task as Confirmed.Jan 19 2020, 8:17 PM
Germano Cavalcante (mano-wii) changed the subtype of this task from "Report" to "Known Issue".
Pasang Bomjan (irex124) closed this task as Resolved.May 3 2020, 7:28 AM
