Grease Pencil Sculpting and selection seem to have some problems when it comes to animation
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.87
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash: rBf1aa4d18d49d
Here is a link describing the problem
Link 1: https://www.youtube.com/watch?v=AhZGuuLzV1k&list=PL-zg5csjHY0goZ5b3puiJsPFXb15w8APo&index=4&t=162s
Link 2: https://www.youtube.com/watch?v=LKXkCtKRDOA&list=PL-zg5csjHY0goZ5b3puiJsPFXb15w8APo&index=3&t=0s
  • Create several Grease Pencil layers, an armature and make the bone for each layer.
  • create a relationship between them
  • lay down some keys
  • and then sculpt over the top
I have included the blend file
Thank everyone
Adam
Jacques Lucke (JacquesLucke) claimed this task.
Please do not simply link to videos to explain the issue.
Also, it seems like you are reporting multiple bugs at the same time here (or why do you need multiple videos?). Make sure you only report a single issue per report.
You should provide a simple step by step guide on how to reproduce the bug (in text form). If possible, provide a simple .blend file to reduce the number of steps that have to be done to reproduce the issue.
I'll close this report. Please open a new report for every bug you found and provide the necessary information.
I think you're being hasty in closing this report. This is only one issue reported here.
That is, " Ghosting happens when trying to sculpt keys".
Sill image explaining the problem.
Gif demonstrating the problem.
I also did some further testing and I think it might have something to do with Grease Pencils mask verts inside sculpt mode.
Please take another look at the blend file.
Here are the bullets points again with more detail.
  • Create several Grease Pencil layers, an armature.
  • Make the bone for each grease pencil layer.
  • Create a relationship between the bone and the layer.
  • Animate the armature into different positions (you will need more than 2 keys in your timeline).
  • After you have animated sculpt on some frames.
In 30 seconds you will see that I go from pose mode to sculpt mode and you can see the problem that happens https://youtu.be/LKXkCtKRDOA?t=932
The blende file was zipped up. Here it is again as just a blend file. Attached is also the system info.
The next 15 seconds shows the problem with selections as well https://youtu.be/AhZGuuLzV1k?t=316
If you have the patience to watch from the above link till 7:51 I will tell you why this workflow is good and how the sculpting selection/ ghosting issue is a problem.
lol, you want developers to watch 2 videos which include a video of 28 minutes to understand your problem?
And not to mention you also "cry" on twitter after this...
What are your expectations here? How can I help you?
