Broken: version: 2.83
Worked: 2.79b
The bounding box(dimensions) updating with delay in drivers.
- Open:
- Select the box.
- Change the x dimension of the box (Note that the cylinder is updated).
- Select the cylinder.
- Go to the drivers.
- Remove the dummy variable.
- Change the x dimension of the box (Note that the cylinder is not updated).
Also, I create a topic on blenderarist.com with ideas for better driver workflow. Please check them.
Drivers update -topic
