OS: Windows 10
CPU: Xeon 1231 v3
GPU: GTX 1070 Strix 8gig
RAM: 32gig
Blender v 2.81a
Broken: Using Ctrl-p to parent objects works fine after fresh install but something unknown to me breaks it and the command will no longer register via keyboard shortcut regardless of wiping the cache and/or factory reset.
Works fine if selected manually from a tab/window, but keyboard shortcut is perpetually broken on all installed versions of blender until all versions are uninstalled/reinstalled.
For me at least, the attached .blend file will not allow parenting of any kind if the command is called via the ctrl-p shortcut. parenting can only be done through a menu regardless of whatever mode is currently active.
