Black dotted line hovering over Shader AOV "Type" dropdown
Closed, ResolvedPublicBUG
Operating system: Linux-4.15.0-45-generic-x86_64-with-debian-buster-sid 64 Bits
(This does not happen on the same PC running Windows 7 x64)
Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken: version: 2.83 (sub 2), branch: master, commit date: 2020-02-03 13:07, hash: rBf037244e2cbd
  • Render Engine Cycles, View Layer properties, Passes -> Shader AOV panel
  • Create a new AOV and hover over the Type dropdown (it says "Color" by default)
  • A black dotted line appears to the left of the list:
(top is screenshot, bottom is edited to make it easier visible)
Aaron Carlisle (Blendify) changed the task status from Needs Triage to Confirmed.Feb 3 2020, 11:15 PM
Aaron Carlisle (Blendify) changed the subtype of this task from "Report" to "Bug".Feb 4 2020, 4:29 AM
I cannot reproduce it.
Operating system: Linux-5.5.8-arch1-1-x86_64-with-arch-Arch-Linux 64 Bits
Graphics card: AMD NAVI10 (DRM 3.36.0, 5.5.8-arch1-1, LLVM 9.0.1) X.Org 4.5 (Core Profile) Mesa 19.3.4
Aaron Carlisle (Blendify) changed the task status from Confirmed to Needs Information from User.Mar 11 2020, 11:35 PM
I could no longer reproduce either, does this still happen @RedMser (RedMser)
Still happens for me on version: 2.83 (sub 8), branch: master, commit date: 2020-03-12 00:33, hash: rB8751af6d1902 with the same system info as in the task.
The length of the line seems to vary greatly, for example it's much shorter with factory startup (in that case, it doesn't even extend past the dropdown area - but it still shows up under the same conditions).
Creating new panels via splitting also affects this.
If there's anything I can do to help fixing the issue, let me know.
Aaron Carlisle (Blendify) changed the task status from Needs Information from User to Needs Information from Developers.Mar 16 2020, 9:42 PM
@RedMser (RedMser) I am checking on old reports, and there is good chance this has been already fixed. Can you still reproduce this in latest builds?
Aaron Carlisle (Blendify) changed the task status from Needs Information from Developers to Needs Information from User.Nov 25 2020, 8:17 PM
RedMser (RedMser) added a comment.EditedNov 26 2020, 4:56 PM
Just tested in 2.91.0 and the bug is fixed there, no problems anymore.
Still happens in LTS 2.83.9 but this probably isn't important enough to backport, if the exact commit that fixed it isn't known.
Richard Antalik (ISS) closed this task as Resolved.Nov 26 2020, 5:07 PM
Richard Antalik (ISS) claimed this task.
Thanks for update. I think this is very minor glitch for LTS at least on the surface. We would have to bisect to check what fixed this.
