Still problems with smoke/fire simulation and rendering in Eevee and Cycles
Windows 10 Pro, 64 GB RAM
AMD Ryzen 9 3900X (12x 3.8 GHz), MSI X570 Unify
GeForce RTX 2070 Super 8 GB, NVIDIA driver version 431.86 (Studio)
Broken: 2.81a Release (and all after)
Worked: 2.79
Quick effect, smoke simulation does not render in Eevee and Cycles, while it shows up in view port and animation is baked and entire project is saved.
Only "Workbench" render engine renders the view port. This problem was not present until 2.80 release.
View port with animation: OK
Eevee Render: NOT OK
Changing view port shading: NOT OK
Cycles Render: NOT OK
Workbench Render: OK
To reproduce this bug it is best to download this file and just try to render in Eevee or Cycles:
https://www.miikahweb.com/other/blender/fire_pillar.blend
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Feb 6 2020, 6:52 PM
I am not sure what exactly are you reporting.
When I open new file, I add quick smoke to cube, bake and render it works OK.
In file https://www.miikahweb.com/other/blender/fire_pillar.blend smoke domain has no volume shader, so it won't render in eevee or cycles as smoke.
Richard Antalik (ISS) closed this task as Archived.Feb 26 2020, 11:28 PM
Richard Antalik (ISS) claimed this task.
