Snapping tool causes Blender to crash
Ever since the snapping tool was introduced it causes Blender to crash very frequently. (I use the tool almost on a daily basis). However, I haven't been able to find a consistency in what could cause the crashes, neither the steps I take nor which file seems to matter, it keeps happening. I use the tool mostly in object mode and mode set to 'closest'.
I would suggest to take any file with any Blender version and work with the tool for a while.
OS: XP Prof 32 bit
3D card: Asus 7600 GS 512 Mb
Blender: from 2.43 till 2.45 RC2
PS A few months ago I got a new pc (with the specs above) and the problem is there exactly the same.
Hi this is probably a issue with your graphics card, a bug report with the same problem was just closed - try turning down/off your hardware acceleration and see if that fixes it. Also try ungrading to your latest graphics card driver.
I'd be interested in narrowing a bit more where the problem might be here.
- Does it crash when you snap to the edit mode mesh or only when you snap to another object?
- Does it depend on the snapping mode (closest, median, center) or is it independent?
To go any further, we'd have to use a custom Blender build. If you can build Blender yourself, that'd be perfect, otherwise, I could arrange something to provide test builds for you.
Tom:
I changed the hardware acceleration setting of the GPU from the default 'Multi display performance mode' to 'Compatibilaty performance mode' (I use only 1 display), since then I haven't experienced any Blender crashes.
Martin:
Untill now the solution offered by Tom seems to fix the problem. I use the tool at closest mode for quad meshes only, no multires or subdivisions or anything. In contrary to what I wrote originally I use the snapping tool in edit mode only (not object mode).
So... can be closed? Let's move this to opengl tracker.
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:37 AM
